7.5" or 7.625" ?????
Car: '85 IROC
When did the 10-bolt ring gears go from 7-1/2" to 7-5/8"? The Helm says 7-5/8 for '85, but the gear that was in there was 7-1/2" with a GM part number. (The original gears were 3.23, since it was an automatic and I don't know where the 3.73 gears came from.) When they were replaced with new Richmond gears, the box said 7.5 but I didn't actually measure the ring gear. Maybe I will when I change the oil sometime.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Car: 82 camaro SC
They both work on the same carrier and are basically the same strength. The Richmonds stronger than stock gears anyway and I think they are 7.625 when measured(but not sure).
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Even aftermarket gears are still called 7.5 even though they are 7.625. 7 1/2" is just a generic term labeled to our diff. Both will fit on the same carrier.
Numbah-1
Sep 12, 2015 08:57 PM
hectre13
Aug 26, 2015 08:17 AM
