gear end bearing
Old Jun 30, 2001 | 09:28 PM
2thpick's Avatar
gear end bearing
I think I have a bad bearing in my car's rearend. I can move the yoke coming out of the rearend up and down a little, and when driving I hear bad noises when I hit bumps.
How much will it cost to get those bearings fixed on my existing rearend? I'm guessing a junkyard rear will be cheaper but I just wanted to see if anybody would have an idea.
1991 Camaro RS 305 5spd
-Factory AC delete car
-IROC Hood
-IROC Wheels
-IROC Grill
-Blue Neons
-Bowtie Foglights
-Smog Delete
-Hooker Headers
-IAT Relocated
-2000 S10 Deco CD Player
1994 S10 2.2 5spd
-Dixie Horn, Air Horns, Knight Rider Lights, 172,000+ miles
http://www.geocities.com/david_somers
Old Jun 30, 2001 | 10:34 PM
82camaro's Avatar
Car: 82 camaro SC
Usually bumps won't cause a bearing noise, it will be constant. If that bearing has been loose for a long time it may be damaged. What does the noise sound like? A junkyard rear probably needs bearings as well.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 1, 2001 | 09:28 PM
2thpick's Avatar
The sound is like a loud rattle, like something heavy is loose. I got the car about 2 years ago, it did it then. I only drove it 4 months before the motor went, I got it back on the road last month.
Old Jul 1, 2001 | 10:54 PM
82camaro's Avatar
Car: 82 camaro SC
Check your tranny mount.
82camaro
Old Jul 5, 2001 | 11:28 AM
2thpick's Avatar
The noise is under the back seat. The tranny mount seems alright.
-IROC Hood
-IROC Wheels
-IROC Grill
-Blue Neons
-Bowtie Foglights
-Smog Delete
-Hooker Headers
-IAT Relocated
1994 S10 2.2 5spd
Old Jul 11, 2001 | 10:18 PM
2thpick's Avatar
Found the big clunk. It isn't the rear end making that noise. It's the panhard bar, it's joint has play in it.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
gwade12
Aug 8, 2015 08:17 AM
