Which Trany lines are in and out?
Old Jul 12, 2001 | 06:08 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I am installing a torque convertor and transmission cooler this weekend and want to double check if the lines going into the radiatior is the top one or the bottom one. I thing that it makes engineering sences to flow coolent down w/ the help of gravity but sometimes the OEM do crazy things.
'84 Camaro w/ Large Jouranl 327 bored .030 over; 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
Work in progress is Sponh Torque Arm just installed working towards 2400 stall convertor. www.chartermi.net~brodgers
Old Jul 12, 2001 | 06:12 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I always get confused by this, but I believe the bottom line on the radiator is the inlet to the radiator. The idea isn't to have gravity help (you'd still have to get it up to the top if that's where the inlet was anyway), but to prevent aeration due to splashing of falling fluid.
Old Jul 12, 2001 | 08:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The top one on the rad is the outlet from the cooler. It goes to the top fitting on the tranny.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jul 12, 2001 | 08:24 PM
Car: YTG Camaro
Engine: 383
That makes some sence but that sucks! I will just be harder to route the lines. FYI - I can turn start the car because the trany is out. Thanks for the help.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
romcjr
Sep 17, 2015 05:18 PM
TBRays98
Sep 6, 2015 05:05 PM
