Where to get speedometer gears
Old Jul 12, 2001 | 04:32 AM
BOWTIROC's Avatar
From: Coulterville, IL...Currently on Beale AFB, CA
I need the complete driven assembly for a 3.70 gear rear with a T-5. Where can I find this?
Black 89 IROC...355, Solid Crower Cam, TFS heads.
12.0 @ 120.3mph with a 1.9 60ft...all motor
Old Jul 12, 2001 | 12:44 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
When I need speedo gear drives I go to the local GM dealer they are most helpfull.
The info you will need is transmition type along with serial numbers to make sure, rear end ratio and tire size, the dealer is always very helpfull with thng like this.
SSC
Old Jul 13, 2001 | 03:45 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I used a 7 tooth drive gear and a 20 tooth driven gear for my T5 and 3.70 gears, with 255/50-16" tires. You can still get the speedo gears from the dealer.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
