Clutch debris on Filter. W/in
Old Jul 10, 2001 | 08:05 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I was looking at that 4L60 trans again that I'll be soon installing into my IROC. I noticed that the filter wasn't nice and shiny like everything else in the trans, so I decided to wipe it off. Rag turned black with clutch material. So basically, the filter housing was coated with clutch material. Is this a sign of excessive clutch wear, or is this fairly normal on a trans that hasn't had the fluid/filter changed in a long time? The fluid didn't smell burnt, but it does seem to be a bit dark and somewhat brown in color.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jul 11, 2001 | 03:08 PM
Jim85IROC's Avatar
anybody?
The IROC Homepage
Old Jul 12, 2001 | 07:19 AM
Jim85IROC's Avatar
Seriously. Nobody knows this?
The IROC Homepage
Old Jul 13, 2001 | 07:06 AM
Jim85IROC's Avatar
ttt
The IROC Homepage
Old Jul 13, 2001 | 07:37 AM
scotia's Avatar
Car: 82 Trans Am
Engine: 305 Crossfire
Transmission: 200c Auto
Jim , I'm not an expert on automatic boxes, but one thing i've been told is "any colour other than red is bad news" - if the fluid is a dark brownish colour, then it has overheated at some point, if there are traces of black specks in the fluid, it generally means heavy wear of the internal clutches / brake bands, so I gather this does indeed point to excessive clutch wear !
An overhaul of the box will probably be in order....
regards
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulasOnly
Oct 2, 2015 05:52 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
