Is a turbo 400 worth it?
I have a turbo 400 that came with my 84z when I bought it at the used lot. Mechanics say that tranny shouldn't fit. I'm a standard guy, and would love to do the swap from the three speed auto to a four or five speed stick, but everyone tells me to keep the 400. Is it really worth it? Do I really not have enough hp from my v8 to run it? And why do I top out it's third gear at 70 mph? Give me some ideas.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Topping out third gear at 70 mph? That's as fast as the car can go? You must have something like 5.13 gears in the rear end and a red line of 4000 rpm.
The TH400 will fit but it's a tight squeeze. If it's a TH400 then someone has swapped out the old 700R4 and put that one in. No third gens came with a TH400. The TH400 is a heavy tranny that can take more abuse than a TH350 or 700R4 but it's not really required for a low HP car. My race car only uses a TH350.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Hotrodboba400
Dec 10, 2019 07:07 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
