Tranny cooler
Old Apr 7, 2009 | 12:39 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Tranny cooler
Got a question about how much trans cooling I should have. Right now I am running a 700r4 with a 2800 stall. The fluid is going through the radiator and then through a 19,000 GVW B & M cooler, stacked plate style. The problem is that I got a bad leak coming from the bottom line on the radiator because the brass fitting(on the rad side) is stripped. I did some research to see how much cooling the tranny should have and it looks like ppl running just an auxilary cooler usually run ones around 30K or so. Should I just buy another 19K B & M one and run it in series and bypass the radiator? that way Ill have 38k which should be more then enough right? Also I am installing a vette servo at the end of the week if that changes anything.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
FormulasOnly
Oct 2, 2015 05:52 PM
apie2546
Sep 5, 2015 07:40 PM
