speedo stopped working. engine light came on
Old Apr 7, 2009 | 10:44 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
so my speedometer stopped working today and shortly after i realized my check engine light was on. my car has the Vehicle speed sensor. i just changed both the driven and drive gear do to a different rear ratio. is it safe to belive that the speed sensor is causing the light to be on?
Old Apr 8, 2009 | 04:04 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: speedo stopped working. engine light came on
Pull the code if your SES is on. THen you will know what that code is. If your SES light is on you know something is wrong. Could be the speed sensor or it could be something completely different. You wont know till you have that code number.
Old Apr 8, 2009 | 09:35 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I'd bet on the VSS or gears, since you just changed them, and the speedo stopped working, then the SES light came on.
Pull the VSS out and check the gears.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
