TTA tranny
Old Jul 18, 2001 | 11:46 AM
91z4me's Avatar
TTA tranny
Why was the TTA tranny different from the 700r4? Can the 700R4 handle the torqe or power why did they use anything different. Just curious.
Old Jul 18, 2001 | 01:01 PM
MonteCarSlow's Avatar
Car: 1988 Monte Carlo SS
Engine: 5.7L TPI
The bell housing bolt pattern of the 700 is incompatible with the Buick 3.8 turbo motor.
The TH200-R4 that the TTA comes with has a dual pattern bell housing so that it can be mated to Buick, Pontiac, Olds and Chevy motors.
I ditched the TH200C in the wife's 83 TA for a TH200-R4. Gained 5mpg...! Other then the cross member modification, it's a bolt in.
Old Jul 18, 2001 | 09:04 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the reason they used a 200 was ease of innstallation(same bolt pattern and the 200 has less of a drop from 1st to 2nd keeping the turbo spining where it wants to
87 trans am 350,L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,tb bypass,accel supercoil,hollowed maf,slp 3in. catback,a/c delete.
oh!no!i think my maf is going!!!!!!!!!!!!
14.10@97mph w/2.01 60'
slp catback is finally on!!!
fastchip prom is in.OH!MAN!
FLOWMASTER S.U.C.K.S
Old Jul 18, 2001 | 09:26 PM
Pro Built Automatics's Avatar
The 2004R is slightly stronger than the 700R4, has a better gear ratio spread, and is about one mph faster & and a tenth quicker in the quarter mile. I have built many of each, and when set up correctly the 2004R can hold a pretty good amount of horsepower. There are many mid nine second Gran National's running the 2004R successfully. If you have any questions concerning your unit, give me a call or email me at probuilt1@earthlink.net, 800 7763288 Mon-Sat 11-7 PST.
Hope This Helps!!!
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
paul_huryk
Oct 1, 2015 04:27 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
