Royal Purple Gear Lube Oil
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
GM recommends 80w, 80W90 GL5 gear lube, + GM additive #1052271 for limited slip differentials for my KITT
I want to use Royal Purple 75w90 Gear lube to my rear end, will it screw up my rear end? Should I add the additive or not? or use something else?
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Re: Royal Purple Gear Lube Oil
Hi:
It will not hurt the rear End. Just stay with the same weight that GM Recommends. I
I had used the Royal Purple Gear oil before in my 85 Trans Am with Australian 9 Bolt Rear End, it was good. I did not add any other additives. I have since switched to Amsoil Gear Oil for the Rear End.
I have been using Amsoil Syntheic Oils in the engine and their products seem to work very well my cars. Just a personal thing I guess.
Rob
Rob
ambainb
Apr 25, 2016 09:21 PM
gixxer92
Sep 1, 2015 04:32 PM
Navy8125
Aug 21, 2015 09:32 AM
Navy8125
Aug 17, 2015 01:29 PM
