speedo gear compatibility
Old Apr 12, 2009 | 12:33 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Will it be okay to run the 15 tooth drive with the 37 tooth driven gear for awhile or they not supposed to be used together. I'm waiting on a housing for the 41 tooth i have to put in. The only reason i ask is because when i turn the tires by hand there is a clicking sound from what sounds like the speedometer gears in the tranny.
Old Apr 13, 2009 | 03:14 PM
Car: 86 Z28
Re: speedo gear compatibility
I'm going to assume that these CANNOT be used together then??
Old Apr 13, 2009 | 06:59 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Of course they can. The real issue is much more likely that the 15 tooth gear is cracked.
Old Apr 13, 2009 | 09:22 PM
Car: 86 Z28
That would really suck if that gear is cracked i just put it in there brand new from gm
Old Apr 14, 2009 | 12:18 AM
Car: 86 Z28
Well i pulled the driven gear and housing off and everything was fine, the clicking was just something in the tranny, so i will leave it until i get the correct parts.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
