How to skip the book method to adjust you TV cable?
Old Jul 23, 2001 | 01:13 AM
maksik7's Avatar
Can somebody please post how to adjust the TV cable properly. I tried following the book but its worded confusingly (Haynes). I remember somebody posting "Skip teh book method on adjusting it, and do this..." several times? Can you please post it again?
Old Jul 23, 2001 | 08:41 AM
transfixleo's Avatar
Here goes: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Old Jul 23, 2001 | 03:23 PM
maksik7's Avatar
Thanks a lot transfixleo,
That was exactly what I was looking for
-Max
corey8084
Brakes
Sep 15, 2015 08:14 PM
scottmoyer
Sep 7, 2015 07:06 PM
dimented24x7
Sep 6, 2015 03:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
