ls1/t5
Old Apr 13, 2009 | 02:03 PM
89lt1's Avatar
Car: 1989 firebird formula, 1991 z/28
Engine: none LSX! one day, 350tpi
Transmission: none t56 one day, t5
Axle/Gears: 9-bolt 3.45, 10 bolt 3.73
ls1/t5
is there any way to run a t5 with anls engine. i know its not ideal i cant afford to do a whole ls t56 swap right now
Old Apr 13, 2009 | 07:25 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: ls1/t5
Originally Posted by 89lt1
is there any way to run a t5 with an ls engine. i know its not ideal i cant afford to do a whole ls t56 swap right now
Possibly with a conversion bellhousing (McLeod), but you'll be throwing good money at bad. The crank flange is further in towards the motor to accomodate the longer LS1 T56 input shaft, and internal hyd slave cyl. Conventional (stock) T5/4-bolt bellhousings are sized for the SBC crank flange, which will leave a gap between input and crank/pilot.
