which rear end to use
Old Apr 14, 2009 | 06:24 PM
nabisco's Avatar
i have a 92z and a 87 2.8, and doing a v8 swap into the v6 car and want to know if the rear ends are the same or if the z one will be better?
Old Apr 14, 2009 | 06:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: which rear end to use
Check the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 14, 2009 | 07:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's no such thing as a V6 or V8 differential. If they're both 7.5" 10 bolts then they're identical except for gearing and if they have a posi or not. Strength wise, they're roughly all the same.
The 92 will be a better choice because it will have the larger 28 spline axles which all third gens got from 90-92 regardless of engine or transmission. It will have the same tiny 7.5" ring and pinion as the 87 although may be a different ratio.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
