spool for 7.5"?
spool for 7.5"?
I am rebuilding my rear and would like to go with 31 spline axles and a full spool. unfortunately, i can't find a spool to fit the 7'5" rear. does anyone make one?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There is no full spool or 31 spline axles available for the 7.5 10 bolt diff.
You can easily buy aftermarket 28 spline axles that are much better than factory ones. As for locking the axles together you can get a 28 spline mini-spool but it's not recommended for street use. Dirt track oval racing only. It's just not strong enough to handle the stresses produced from tires scuffing across pavement.
If you think you're going to produce enough torque that you need 31 spline axles then you better invest in a 9" or a 12 bolt.
I currently only use 28 spline axles. When I upgrade to 4.56 gears in my 9" I'll only need 31 spline axles.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
thanks for the info. i talked to moser and he told me pretty much the same thing. he suggested the 12 bolt, which i agree is a better choice, i just don't have the scratch to get it right now.
I have a 7.5 one legger with 410s that someone welded the spiders on, works good but skids, a cheap spool if you need one, and doesn't need to come out of the car to do it.If it breaks then spend your money
darwinprice
17
Oct 11, 2015 11:51 PM
