Wiring question.....
Old Jul 28, 2001 | 10:47 AM
BlakCamZ28's Avatar
I have a 700R4 out of an 87 Firebird I belive. There are two electrical connections on the driver side. The first is about halfway down the length of the tranny, is a 4 prong square connector and is pointing straight up. The second comes out the side of the tranny near the tail shaft and is a two prong connectors. What are these connectors and what do they do? I thoguht the 2 prong connector near the tailshaft was for reverse lights but now i'm not so sure. Thanks
Old Jul 28, 2001 | 12:12 PM
82camaro's Avatar
Car: 82 camaro SC
The 4 prong connector controls the torque converter lock-up. The 2 wire connector is for the electronic speedo. The reverse lights are done on the shifter.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
