Clacking Noise??? Torque Converter???
Old Jul 26, 2001 | 06:55 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Ever since I got a tranny rebuild and a used NON lockup converter I have had a clacking type noise under the car. It sounds like it could be coming from around the converter or exhaust. I read someone else posted something about the pressure in the tranny and converter? any ideas.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 27, 2001 | 02:54 AM
transfixleo's Avatar
'Sounds' like a cracked/loose flywheel.
On another note, did you just install the Non-Lock converter? This is not good. If you are on the street you should have L/U but if you use a Non L/U converter you need to replace the L/U apply valve in the pump with the TransGo special valve to prevent lube problems.
Old Jul 27, 2001 | 07:52 AM
Car: 99 Formula
Axle/Gears: 342
Well I am not too sure of the specifics, the guy who rebuilt my tranny told my Dad that he used I believe a hydraulic NON LU. About whether or not about the transgo part I am not sure. Also, the clacking used to come and go, but now seems to be there all the time. I am getting my car worked on in a few days, changing the gears, so I'll have the guy look the car over. Oh, could a cracked flywheel hurt my performance.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
Old Jul 28, 2001 | 05:23 AM
A cracked flywheel could set off the knock sensor and that will affect performance but I would be more concerned about taking the tranny pump out.
Old Jul 28, 2001 | 11:30 PM
Duke901's Avatar
Car: 89 Formula
My 87 SC Camaro is doing the same thing after i had my turbo 350 rebuilt, the noise used to be come and go but know its there all the time and some times it seem like if i have it at higher RPM it goes away and some time is i have it in gear it isn't as bad to so what could the problem be
Old Jul 29, 2001 | 12:04 AM
Car: 99 Formula
Axle/Gears: 342
I think I may have found the problem. I was under my car changing some spark plugs and noticed a metal sensor that connects to the headers. It is a little loose and when I move it with my hand makes the same sound that I hear, but I guess faster since the motor vibrates it.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter, 5" Autometer Tach w/shift lite
88rscamar0
Sep 23, 2015 09:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
Randomtask2
Sep 7, 2015 05:06 PM
