What is a v6 T5 worth?
Old Apr 17, 2009 | 10:54 PM
86transam.man's Avatar
Car: 1986 Firebird Project
Engine: 3.1L
Transmission: t5
I just found a v6 T5 from a Camaro at a scrap yard, all i know is that it goes into all gears and turns and it needs the front bearing replaced. The front bearing is Timkin though, and the car is an 89 or newer?? What should I pay for this?
Old Apr 18, 2009 | 05:59 AM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: What is a v6 T5 worth?
whats the weight of scrap metel in your area? V8 t-5s are almost worht nothing, never-the-less a v6 one.
Old Apr 18, 2009 | 07:32 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Here in East TN the yards charge $300-$350 for a t5 trans .
Old Apr 18, 2009 | 09:27 PM
Engine: 3.1L
Transmission: t5
Well 86camaro383 as you can see I do have a v6, so why else would it be worthless i mean its not like Im putting out that much power.
Old Apr 19, 2009 | 06:19 AM
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
yes, but your buying a tranny that you know, keyword, know your going to have to rebuild.
Old Apr 19, 2009 | 07:48 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
With it needing a bearing I would offer no more than $100 for it . And the only difference in a v8 and v6 trans is the input shaft . This info comes from my local Pontic dealer and a trusted trans shop . All F-body t5s are the exact same inside . The only varyations are between worldclass and non-worldclass .
Old Apr 19, 2009 | 08:26 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
This is not entirely true.. Many of the I4 and V6 T5 had lower gear ratios, to overcome the power difference in those motors. With more low end motor power (V8s), you can use higher gear ratios and still get a vehicle moving. To achieve the lower gear ratio, you must have more and smaller teeth on the gears, and they prove to be the weak link.
So you can claim the only difference is the input, but that same input determines the gear ratios and gear sizes of all the other gears, so replacing the input usually has you replacing most if not all the gears inside also..
Old Apr 19, 2009 | 08:49 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Yes , I forgot about some having different gears .
Old Apr 19, 2009 | 10:47 PM
Engine: 3.1L
Transmission: t5
So, anyone else?? What is it worth? Is the front bearing hard to replace?
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
