Question 2, Weird tranny feeling.
Old Jul 29, 2001 | 12:25 AM
breathment's Avatar
Ok, this question is quite a bit different.
Ok so heres the situation.
1: Car is in OVERDRIVE
2: Speed is about 45-60.
3: Decelerating\coasting.
heres wut the car does, it will be coasting fine, then all of a sudden, the RPMS will drop to like 1000 and u will feel the car slow down, like when u let of the gas on a manual tranny, it will do it for like a second, then it goes back to regular, then it will do it again, pulling the RPMS from 1500 to like 1000 and slowing the engine and car, like u are downshifting, then it goes back to normal. The car does the exact same thing in DRIVE, but at lower speeds. wut is causing this?
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass
Old Jul 29, 2001 | 05:25 AM
transfixleo's Avatar
All I can think of is somehow the L/U (which at closed throttle should be OFF)is cycling on and off. Why? Let me know when you find out- perhaps a missadjusted TPS?
Old Jul 29, 2001 | 05:40 AM
breathment's Avatar
TPS is at .52 volts, could it be the wutever cable that is that connects the throttle to tranny? i feel stupid, the throttle kick down cable thingy? THE TV cable?
[This message has been edited by breathment (edited July 29, 2001).]
Old Jul 29, 2001 | 06:07 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Sounds like brake switch is confusing the lockup converter. Possible is is over adjusted.
Just a shot in the dark....I'm used to Honda's. Been away from V8's for too many years. That is changing!
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Old Jul 30, 2001 | 01:30 AM
breathment's Avatar
Ok, this kidna has to do with this question.
Ok, do u know the feeling when u downshift manualy, and it drags the engine down, well if i drive in DRIVE, and i decelerating, it does the thing were it pulls on the engine brining down the RPM's. but when it does it, the exhaust sounds really really choppy, and if im going say 20 and drop it into 2nd, it does the same thing, realyl choppy sound until the car slows down. But it does it in drive too, would that mean the Torque convertor is locking when it is not supposed to be?
Old Jul 30, 2001 | 11:55 AM
leirch's Avatar
Maybe the tranny is slipping into a lower gear?
Cleotiz
Jan 6, 2018 08:56 PM
87iroctheo
Dec 4, 2016 11:47 AM
NiG
Sep 2, 2015 06:54 AM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
