2.73 to 3.42 -7.5" 10bolt carrier swap q's?
Old Jul 31, 2001 | 01:45 AM
burnoutrpm's Avatar
ok i have a 3.42 rear end out of a s-10 truck 91 model 2wheel drive 7.5" 10 bolt. complete rear end assembely. i want to "gut" the s-10 rear for the 3.42 carrier and pinion. i want to put this in my 1989 formula's rear it currently has 2.73's(yes these suck *** ). my question is since these are both 7.5" 10 bolts, how would this be accomplished in the most cost effective manner? i was thinking to "gut" the s-10's rear and put in everything in mine as it was in the s-10's rear. will this work? i really need some help i know the cost of a shop to have the swap done and its very costly,.plus i would like to learn how to do this swap myself. ............remember i want to swap complete carriers...not just ring and pinion!!!!!!
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1405edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!.with lots of NOS
Old Jul 31, 2001 | 06:04 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes. Just remove the entire carrier complete w/ ring gear and remove the pinion also. Then install into your rearend. Here is a crash course on installing: Rearend
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Orr89RocZ
Apr 25, 2016 08:28 AM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
LT1Formula
Aug 20, 2015 09:36 PM
knight72
Aug 10, 2015 09:32 PM
