need info on swapping in new axle???
Old Jul 31, 2001 | 07:43 PM
jptaylor2's Avatar
how big of a job is it to install the whole new unit. the guys at my local shop said there is no way i could change the gears myself but if i could find a complete axle then it would be rather simple to do in the driveway. also how bad is the conversion from drums to discs on the rear. my other bird came stock with discs but this new one has drums.
jptaylor
1989 formula
jasper 350 (punched to 397ci)
trick flow twisted wedge heads(2.02 intake and 1.72 exhaust)
1.6:1 roller rockers
jacobs omni magnum ignition
isky cam
flowtech jethot coated headers
mufflex 4" mandrel stainless exhaust
no cat
holley 670
open element
custom fixed headlights
97 formula interior
macewen white faced gauges
3.42 posi rear end
baer racing 4 piston calipers front and rear
underdrive pullies
hard wired cooling fans
www.geocities.com/jptaylor2/FIREBIRD.html
IN EVERY RACE THERE IS A VICTOR AND A VICTIM, YOU LOOK LIKE A VICTIM!!!
Old Jul 31, 2001 | 08:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
This should answer your questions 10 bolt install
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
[This message has been edited by GMTech (edited July 31, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
