posi rear end question
Old Apr 20, 2009 | 12:34 PM
redroc33's Avatar
Car: 1984 Z28
Engine: 305 HO
Transmission: 5-Speed
i have an 84 z28 and its a peg-leg i want to make it into a posi. easiest way to do this?
Old Apr 20, 2009 | 12:48 PM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
Re: posi rear end question
you can weld the spider gears, but it make it like a spool. it will lock both wheels together all the time.
Old Apr 20, 2009 | 12:53 PM
rallen's Avatar
get one out of a junkyard or buy the posi unit that takes the place of the spider gears
Old Apr 21, 2009 | 07:01 AM
big gear head's Avatar
The Eaton posi is the best differetnial for most GM cars. It's $445 plus shipping. You will need a set of br=earings and shims to install it. They are $45. I have instructions on installing it.
Don't weld the differetnial. This is very dangerous.
Old Apr 21, 2009 | 07:53 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Get a power trax unit and throw it in and your done. All it does is replcase your spider gears and can be done in your drive way in a couple of hours.
Old Apr 21, 2009 | 10:44 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
YES GO WITH THE POWERTRAX i put one in and its better than any limited slip unit no clutches to wear and you dont have to reset up your gears.it locked both my wheels together 2 great black marks and no binding in the turns either great product.just make shure you find out if you have the 7.5 or the 7.625 thats the only hold up i had
Old Apr 21, 2009 | 11:00 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
If your tight on money....get on ebay and buy a posi unit out of a 3rd gen, I believe '84 uses 26 spline....I don't know for sure what year they went to 28-spline. I am currently using a 4th gen gear set and posi that works great that I believe I spent $100 on. Just an idea, but really read the ads, and check their feedback close, you don't want a worn out rear end....just some food for thought for ya...
Old Apr 21, 2009 | 12:03 PM
The '84 will have 26 spline axles. They went to 28 splines in '90.
Old Apr 21, 2009 | 12:26 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
which do we have?
7.5 or 7.625?
i thought we had 7.625 but now im not sure
Old Apr 21, 2009 | 12:41 PM
redroc33's Avatar
Car: 1984 Z28
Engine: 305 HO
wheres the best place to get a powertrax unit? and would you happen to know which gears i have?
Old Apr 21, 2009 | 12:52 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
summit has them for under 400
Old Apr 21, 2009 | 03:04 PM
Car: 87 iroc z
Engine: 358 tpi
yea summit or i got mine from jegs..ill tell ya how to tell the diff in the 7.5 and the 7.625 firstly yea from what iv seen most f bodys have the 7625 but all you have to do to tell is look at your carrier well look on the ringear first mine was stamped right on it 7-5/8 12-41 the 12-41 are my ring and pinion teeth count.Divide them and you get 3.42 and the 7-5/8 is the 7.625 if it were 7.5 it would have been 7-1/2 and you can also tell the diff by looking at the carrier(what the ring gear bolts to)the 7.5 will have the same windows or openings on each side where you can get at the spider gearsThe 7.625 what you probly have(they came out in most camaros firebirds TAs ect) it will have only 1 big window or opening to get at the spiders youll see what i mean when you look at one ohh yea dont forget to count the axle splines also lol they should be 26 hes right about 28 in the 90s
Old Apr 21, 2009 | 03:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by RED_DRAGON_85
which do we have? 7.5 or 7.625?
The 7.625 (7 5/8) was introduced around 86. 82 to 89 cars have 26-spline axles, though a few 28's may have found their way into late 89 cars; 90 up have 28 splines as big gear head mentions.
JamesC
Old Apr 21, 2009 | 03:27 PM
JamesC's Avatar
...and would you happen to know which gears i have?
If you truly have an 84 305 HO with T-5, then you have 3.73's. If you're unsure, check the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 21, 2009 | 06:17 PM
89 fire-am's Avatar
Car: 89 firebird cross bred w/ a trans a
Engine: 69 ZQ3 vette sbc 355
Transmission: saginaw 4 speed
Axle/Gears: 3.23 powertrax locker
Anyone know if a 7.5 26 spline mini spool will work in a 7.625 carrier?
Old Apr 22, 2009 | 03:42 AM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
How much is the powertrax or w/e it is?
I need a posi too, but I'm only willing to spend up to like 300, 400 max.
There are some rear ends being sold for cheaper than that in the classifieds that have posi in them.
I would prefer to get a new rear end all together that has disc brakes and perhaps a better gear ratio than stock, but if anyone can show me a cheap way of converting my stock rear end to a posi i'll listen.
Stock '90 RS 305
10 bolt rear end, i believe it's a 28 spline axle (i'm pretty sure they changed them to 28 spline in '90).
I dunno what the carrier number is or what the carrier even is, anyone want to enlighten me on this real quick?
Stock drum brakes
Stock 3.08 g/r
Old Apr 22, 2009 | 07:59 AM
Car: 87 iroc z
Engine: 358 tpi
the power trax is abot 400 but well wort it you know its new no clutches to wear you dont have to reset up your gears to install anyone can do it and it will work better than limited slip
Old Apr 22, 2009 | 08:04 AM
Car: 87 iroc z
Engine: 358 tpi
im not shure i know that the power trax wont interchange between them the gears will interchange but the carries are a little differant id look at a mag and see if they offer 7.5 minis and 7.625
Old Apr 22, 2009 | 09:39 AM
89 fire-am's Avatar
thanks
Old Apr 23, 2009 | 07:28 PM
da_jester's Avatar
Car: 1992 camaro rs
this power trax sounds pretty good and easy i have a 92 rs with a 305 i want to make into a 2 wheel peel but id also like to get higher gears then the 2.73s i believe thats in my stock rear.so id probably be better getting a whole new rear huh? cause ive never done gears and idk how to do that shimming stuff and i dont want to mess it up and have a big paper weight lol.
Old Aug 13, 2010 | 07:53 PM
RMR94's Avatar
Car: 92 camaro
Engine: 305 bonestock sbc
Transmission: 700/r4
i have the same deal as da_jester 92 stock rear end i was looking to get a new gears and wanted posi. so does the powertrax do the same thing a posi rear end does? and was also wondering how much new geears would cost cause i really dont plan on getting a whole new rear end thanks for your help
Old Aug 13, 2010 | 09:02 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Powertrax no slip is almost like a posi rear much much closer to a spool. The slightsest bit of torque and it locks up instantly. Takes a couple drives to get use to it. A decent set of gears will cost around $200.
Old Aug 13, 2010 | 09:09 PM
RMR94's Avatar
Car: 92 camaro
Alright thanks ummm when it locks up that means both wheels are spinning the same right? And if I were to burnout would I be doing a two wheel peel then? And does the powertrax affect gas mileage? And what's the differeence between a posi rear end and a powertrax unit? And is it hard to change out the gears?
Old Aug 14, 2010 | 07:21 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Yes, when it locks up both wheels are spinning. And if you burn out then both wheels will light up at the same time. Powertrax dosent effect any gas mileage but a gear change will. Difference between a posi and powertrax is that posi and power trax is more torque sensitive and untimately locks up into a spool. Just the slightest hit of the gas pedal and it locks up. This means in corners,trying to park,ect.Where a regular posi wouldnt. You dont change out the gears you change the spider gears which the power trax takes the place of. Everything else stays put.
Old Aug 14, 2010 | 07:36 AM
RMR94's Avatar
Car: 92 camaro
Alright thanks would you prefer the powertrax or a posi rear end? And does the power trax make It harder to go around corners? What about parking is that harder with it and so if I were to get a power trax and then in the future decided to change the spider gears can the power trax still be used on the new gears?
Old Aug 14, 2010 | 08:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Power Trax = Posi = LIMITED SLIP they are all the same.....
Old Aug 14, 2010 | 08:14 AM
RMR94's Avatar
Car: 92 camaro
But when I was looking at the power trax unit it said no slip
Old Aug 14, 2010 | 08:35 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
The no slip is a better version of the power trax locker. The locker is very jerky and noisy for the street. The no slip has springs in it to be smoother.
Old Aug 14, 2010 | 08:38 AM
RMR94's Avatar
Car: 92 camaro
ooh alright thank you so i was wondering does the power trax no slip make any noise and if it does how much does it make? thanks for your help
Old Aug 14, 2010 | 08:47 AM
DJP87Z28's Avatar
info
Old Aug 14, 2010 | 08:51 AM
DJP87Z28's Avatar
Good for nothing info...
Old Aug 14, 2010 | 11:29 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Originally Posted by DJP87Z28
info
What part of that didnt you get ?? The locker right is nosiy and jerky on the street. Since the no slip has springs in it its much smoother when it engauges.
Old Aug 14, 2010 | 11:30 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Mine dosent make any noise and is very quite.
Old Aug 14, 2010 | 11:47 AM
DJP87Z28's Avatar
The part you did not get is a LOCKER & LIMITED SLIP are two different rear end assembies.
First... A Locker should not be used on a street driven car.
Second...There are different designs of Limited Slips and not all use springs.
Again a lot of mis- info on your part.
Old Aug 14, 2010 | 11:53 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
You need to learn how to read. I never said anything about a limilted slip. I'm talking about the lock right and the no slip in which richmond gear make.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
