slight wihing out of richmond gear
Old Jul 30, 2001 | 11:44 PM
MouseCamaro305's Avatar
i just installed a 3.73 ring and pinion by richmond. followed all the directions and backlash is right. and so is pinion depth. i drove the car and i get a slight whining noise above 12-13 mph. it only whines when l accelerate coasting it's dead silent, and braking its dead silent. turning hard right it makes a slight whining, but hard left it doesnt make any noise. is this normal? l ran it for 10 miles and brought it home. l felt the diff and it wasnt unusually hot. in fact it was normal temp. is this a normal noise?
Old Jul 31, 2001 | 06:01 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes. Richmond sacrifices noise for reliability. These gears are meant for race cars, not your grandmothers caprice.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 31, 2001 | 11:51 AM
ede's Avatar
ede
follow the break in instructions too
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Jul 31, 2001 | 04:17 PM
86SCBNJ's Avatar
I have Richmond 3.73's also... they whine too. After you break them in, change the lube to synthetic, either Redline or similar, use GM Posi lube with it. The Posi lube with the synthetic lube lessens the noise. At least it did for me
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Suspension Techniques Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Nothing easy can be fun...
Old Jul 31, 2001 | 05:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Those all whine a little bit, it sounds to me like yours is OK and you did a good job. Like the other posts said, the Richmonds trade off a little noise for extra strength.
ICON Motorsports
Old Aug 1, 2001 | 12:15 AM
ok thanks a lot for the responses guys, l really appreciate it
db057
Apr 28, 2019 07:45 AM
tgp1990
Sep 4, 2015 06:24 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
