what gears do i have
Old Jul 26, 2001 | 04:45 PM
red350Z's Avatar
i have a 91 z28 5.7 with the g90 performance axle does any one no what gears i would have come with
91 Z28 slp headers adj reg accell cap rotor coil comp cam roller
random tech cats flowmaster catback
Old Jul 26, 2001 | 05:36 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Here is a trick that works regardless if they have been swapped or not.
If you have an auto, put it in D (3rd) and if you have a manual, get it into 4th and do 70 MPH. Then look at your tach.
@ 70MPH:
2.73 = 2730 RPM
3.08 = 3080 RPM
3.42 = 3420 RPM
3.73 = 3730 RPM
4.10 = 4100 RPM
See where this is going? Just count one digit over and put a decimal point there and thats your ratio.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 27, 2001 | 09:07 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
That is a pretty slick way of finding the ratio!!!
Old Jul 28, 2001 | 03:10 AM
u r sofa king we tah did's Avatar
its just basic math. auto 3rd gear and standard 4th gear are 1:1 ratio.
Old Jul 28, 2001 | 07:33 AM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
What tire diameter is that formula based on and how much does tire diameter effect the results of that formula?
What about convertor slippage?
LOBC-- SS-84
92 RS Heritage package with a 305 3" high-flow cat and pipe with a Dynomax 3" in dual 2 1/2" out.
84 El camino- 383 CID, Performer RPM, GMPP vortec heads, Holley 750 D.P.(0-4779c), Crane Energizer 274,Dual 3" Flowmaster 40 Series Exhaust, Turbo 350 (375b), TCI 2500 stall, Richmond 3.42 gears, PST Poly graphite Suspension bushings, PST steering linkage, PST springs, Monte SS sway bays, Wheels from a Third gen(does that count?)
Old Jul 28, 2001 | 03:06 PM
your converter should be locked up at highway speeds
Old Jul 29, 2001 | 07:42 AM
SS-84's Avatar
Car: 1992 RS
I was mainly asking those questions so if I go to buy any car that i could use this trick formula. Say like a first gen or an older A-body.
LOBC-- SS-84
Old Aug 1, 2001 | 12:46 AM
Curse Z28's Avatar
Tire Diameter should not affect it much, atleast not enough that you cant determine what it is.
ie if you are turning say 2800 rpms you should be able to figure out that you are running 2.73s
Old Aug 1, 2001 | 01:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
All 90-92 L98's come with automatic transmissions, G92 performance options, dual cats, and 3.23 gears.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
