Rear Questions
Old Jul 31, 2001 | 10:27 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
Rear Questions
Just a couple things about rears I think you guys might be able to help out with:
- I have a 3.08 posi in my TA (posi still works). From what I understand, I can just buy new gears, NOT the whole rear end, right? of course i might wanna get some nicer PARTS for the rear when i get the gears put in also, but is my assumption CORRECT?
- Also from what i understand, rearend fluid doesn't need to get changed much, but I'm pretty sure mine's never been touched. What level does it need to be filled to when I check it on thursday?
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS, The F-Bod Squad, 3 guys so far and I don't think we're growing
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
AOL IM Name: JimmyTime5
Old Aug 1, 2001 | 12:59 AM
Car: '89 TA
Engine: LB9
Transmission: M5
bttt
Old Aug 1, 2001 | 11:06 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Yes, you can get just gears.
Fluid level should be at the fill plug.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon )
www.koolmeister.com
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
