What type of 700R4 is this
Old Apr 21, 2009 | 08:11 AM
ta_nhra02's Avatar
What would a 700R4 out of an 89trans am 350TPI, be? Is it a spedo. or electric? What size should the tailshaft be? What is the electric piece that goes to it? Like 3 or 4 wires? Is it a TV setup? I have no idea. I'm a rookie! Thanks!
Old Apr 21, 2009 | 10:23 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Re: What type of 700R4 is this
heres a pic that might help id your trans also you should have the electric speedo it has 2 wires and plugs in the tail shaft driver side.if its mechanical it will have the screw on type cable and the tail should have 3 bolt holes for the torque arm.and should have 1 more square plug for the lock up torque converter about mid way of the trans with about 3 wires.i have some more id info but you have to have the tranny apart to use it.i got this manual with the transpack shift kit i installed in mine hope i helped
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
92projectcamaro
Sep 29, 2015 07:07 PM
6998poncho
Sep 25, 2015 02:56 PM
