Leaking Rearend (G92)
Old Apr 21, 2009 | 03:39 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
So I finally made a purchase on a car out of state and I'm having it shipped. I noticed the rear end is leaking.
Is this common?
Should a new gasket do the trick?
Old Apr 21, 2009 | 03:48 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Leaking Rearend (G92)
Is this common?
Leaking where? A gasket or RTV will fix the diff cover on a 10-bolt (the nine-bolt may be a different story with its plug). If the rear is weeping at the axles, you'll probably need bearings, seals (or axle savers), and axles.
JamesC
Old Apr 21, 2009 | 04:23 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Here is a pic of the rear end
http://i677.photobucket.com/albums/v...5/000_1564.jpg
Old Apr 21, 2009 | 04:36 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
Looks like just oil residue. Clean all the oil off. Then just keep a eye on it to see if you have a valid leak. Not worth fixing something that isn't broke.
Old Apr 21, 2009 | 05:35 PM
JamesC's Avatar
Could be leaking at the axle tubes. If so, major problem. As CBR mentions, however, clean it and keep an eye on it for a while.
JamesC
Old Apr 22, 2009 | 03:19 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Take the cover off, scrape the old gasket off the cover and the diff, put in a new gasket with RTV on both sides to seal in up. Put a small bit of RTV on the bolt threads as well before you thread them in. Put in new oil and (if needed) posi additive. Drive and monitor.
I say just do this anyway, because like 99% of RWD cars out there, its probably long overdue for an rear end oil change anyway.
Old Apr 22, 2009 | 06:41 AM
big gear head's Avatar
It could also be the pinion seasl leaking and the oil is blowing back on it. You need to clean it up and see where the oil is coming from.
Old Apr 22, 2009 | 11:55 PM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
Thanks guys. I will look into it further once I get the car. It will be on a car hauler from San Jose in about 3 days
Just wanted some opinions from the experts of third gens.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
