GEAR DIFFERENCE (2 and 3 series)
Old Jul 30, 2001 | 03:44 PM
MightyMouse's Avatar
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
What is the physical difference of a 2 series carrier gear and a 3 series carrier gear of the same ratio. I bought a used one and dont know wich one it is. All I know is that it is 3.23.
Old Jul 30, 2001 | 07:51 PM
82camaro's Avatar
Car: 82 camaro SC
thickness of the ring gear. The 2 series is thicker of the same ratio gears. Factory gears are 3.23 and higher-3 series. 3.08 and lower-2 series
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 1, 2001 | 06:10 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
How thick is the 3 series ones?
Old Aug 2, 2001 | 08:33 PM
82camaro's Avatar
Car: 82 camaro SC
Depends on the gear ratio. The higher the gear ratio(number wise), the smaller the pinion must be--since it has to have less teeth. The ring gear must then be thicker to compensate for the smaller ring gear. This is why they have 2 and 3 series gears. If they didn't the 2.73's would have a thin ring gear and 4.11 would be really thick.
82camaro
Old Aug 2, 2001 | 09:44 PM
agawam's Avatar
I have a set of 410s for series 2 the ring gear is about 2 1/2 in thick the series 3 410 is about 1 3/4
Old Aug 2, 2001 | 11:41 PM
Car: 90 RS
Engine: 383
Axle/Gears: 3:23
OK thanks for clearing that up for me.
Time to buy more stuff.
hectre13
Dec 11, 2023 08:14 AM
fasteddi
Sep 2, 2015 10:29 AM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 25, 2015 08:25 PM
knight72
Aug 10, 2015 09:32 PM
