Speedo recalibration on 700r4.
Old Aug 2, 2001 | 09:56 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
Where can I get the drive and driven gears to recalibrate the speedo? I installed a Moser 9" with 3.70's and originally had 2.77...does anyone know the tooth combo's for recalibration or where to get them...I called Lingenfelter about it, and they halted making the gears for a while, saying they are too time consuming to make; that they have to make one by hand and give you the GM other gear...that was his explanation for being so expensive($130).
1989 Chevrolet IROC-Z28 TPI ZZ4 with TH700R4 and 2.77:1 rearend gears:
-Gutted Air Boxes, Throttlebody coolant bypass, Hypertech Air Foil, Accell Superram Base Intake, Crane AFPR, AC delete, Smop pump delete, Hooker 1 5/8 Headers, Holley Ignition Module, Hypertech Custom PROM, B&M Megashifter...I know there is more, I just can't think of it right now!
Old Aug 3, 2001 | 12:31 AM
Omar's Avatar
Assuming 245/50/16 tires,
you need:
15T Drive (8642620)
45T Driven (9775187)
You can get them from the dealer.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
ZZ3Astro
Aug 13, 2019 12:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
IROCZ1989
Sep 4, 2015 11:54 AM
