Swapping V6 and 700R4 to a V8 and TH350
Old Aug 3, 2001 | 12:30 PM
White_Boii's Avatar
This subject may have been discussed many many times before, so this should be no prob for you guys...i know on the tranny i need the B&M adapter thing for the torque arm, and a driveshaft from an 82 4 speed or sumthin like that if i get the 6" tail...but will i need new tranny mount(crossmember i think its called? maybe, i dunno) if one of yall could explain what all i will need, i would GREATLY appreciate it, thanks guys!!!
Old Aug 3, 2001 | 05:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since the frame rails to which the rear crossmember mounts are not parallel, changing the length of the transmission requires a different length crossmember.
A 6-inch tailshaft TH350 would require a shorter crossmember than a TH700R4.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
89newfun
Sep 16, 2015 09:28 AM
Randy82WS7
FAQ Board
Jun 18, 2013 09:58 AM
ThUnDeR2005
Jun 10, 2009 12:39 AM
AlbertaFbody
Sep 2, 2008 02:31 AM
88Camaro350
May 24, 2005 01:56 PM
