Wanna rebuild 700r4 with shift kit...
Old Apr 22, 2009 | 08:39 PM
liljon285's Avatar
Car: 1987 IROC
Engine: 5.0 TPI all stock
Axle/Gears: G92 G80
I am low on cash but my tranny needs a rebuild it only has first gear. I also want to add a shift kit, i wish i could go with transgo as it is what everyone reccomends but I have found this and think it might be a good solution. So yea...is this any good? If not Please tell me any suggestions. My budget is $270( i have a friend doing the labor for me).
http://www.bmracing.com/PRODUCTS/Bui...-not-for-4L60E
Old Apr 24, 2009 | 10:48 AM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Re: Wanna rebuild 700r4 with shift kit...
I need to rebuild my trans to.. tough I have one more gear then you
Been thinking about this kit or the TCI one..
Some help chosing one would be great...
Old Apr 24, 2009 | 10:59 AM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
That is a decent kit if your budget is limited. The shift kit is included so that will save some money. If you go this route just keep in mind that some of your hard parts may be damaged and this kit doesn't replace any of them. You are also going to want a new or rebuilt torque converter and don't forget to flush your factory cooler while the trans is out. And add an additional cooler for added tranny life.
Old Apr 24, 2009 | 05:35 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
I have a local shop that will give me a high performance overhaul kit and a transgo shift kit, both separate items but for a combines price of about $175. Im not sure what transgo shift kit it is but the kit itself is $90. I am thinking of going with that. How much would a rebuilt torque converter run for?
Old Apr 27, 2009 | 11:24 AM
dippo6's Avatar
i highly recomend tci's rebuild kit, i did the upgraded performance kit, larger servo's an 1800 stall converter from them and a stronger reaction sun shell since i cracked it and was missing 2 gears.. i also did the firmest shift for the shift kit from them and the thing is like gold been running it for over a year now
Old May 8, 2009 | 05:02 AM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Ok so i went with the Trans=go junior shift kit. I have yet to know whether I am happy with it or not because the tranny is still being built. The overhaul kit and shift kit was $130 but it turns out i had to waist another $140 in clutch gears and a **** load of internal parts that the owner before really burnt up. So I have wasted about $300+ on this tranny its pretty much gonna be new on the inside...oh and i got a high stall converter...guy said it should be around 2400-2500 stall, im happy with that.
Old May 8, 2009 | 07:10 AM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Shift kit is not a rebuild kit.
Old May 8, 2009 | 05:01 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Yea but an overhaul kit is
Old May 8, 2009 | 06:30 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Still what kind of rebuild kit does not include clutches?
Old May 8, 2009 | 06:32 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Yea all clutches and little gaskets and such...its a Heavy Duty kit i dont remember what brand but its from a local transmission shop.
Old May 8, 2009 | 06:37 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Im confused..
each? I belive just the shift kit is about 130$...
So the overhaul did not include those..?
I really dont get it
Old May 8, 2009 | 06:39 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
No overhaul kit is just gaskets and little seals the things that NORMALLY wear out on the tranny but this tranny was SUPER BLOWN! lol and no the shift kit and the overhaul kit was $130...i got the hook up
Old May 8, 2009 | 06:46 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Ok..
The gaskets and seals is no rebuild for me its just.. I dont know.. "I want to look inside" kit
For me normal rebuild kit has the clutches which are normal to change..
And then there are the "true" rebuild kits which include the "hard parts" that usually wear very little or so..
Old May 8, 2009 | 06:49 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Yea thats exactly what i needed to buy extra...the hard parts. Sorry if im a bit underinformed its my auto shop instructor building the tranny he used to specialize in gm trannies so he it like teaching me. Oh and today we found that the check ball for the first gear was missing and the vlve body ws already drilled on the "F" hole...so thats probably why it blew up lol.
Old May 8, 2009 | 06:54 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
What I have decided is to buy a kit from Dana's Probuild:
http
;//www.700r4l60e.com/store/product.php?productid=41&cat=19&page=1
which is expensive but have EVERYTHING that wears out. And stronger parts too.
It will allow me to make one, big rebuild and have a lasting transmission for a big while.
Old May 8, 2009 | 06:57 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
What i should of done is opened up the tranny before i bought everything....that kit is actually not expensive at all. I have about $320 in the tranny already and still not EVERYTHING is new...that would of been a good investment i think. Well ill learn from it...its my first tranny build and I have learned a lot...an automatic transmission is pretty amazing!
Old May 8, 2009 | 07:06 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Yeah, the price is pretty good.
The "normal" kits goes for about $250 and they dont have the parts that "wear little"..
Like I said - when rebuilding such sick and magicly complicated thing like transmission (that is my opinion - I belive it was invented by alien race, too complicated to be made by human ) it is much, much better to rebuild it once real good to avoid doing it again
Old May 8, 2009 | 07:09 PM
liljon285's Avatar
Car: 1987 IROC
Axle/Gears: G92 G80
Yea im definitely going with one of those kits in the future with another f-body cuz i know ima have more lol
Old May 8, 2009 | 07:17 PM
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Plus this kit is good to 575+ HP and gives you manual 1-2-3 and full automatic function
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
TheTraut88
Sep 7, 2015 05:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
