Changing tranny gear.. Which one?
Old May 7, 2009 | 06:18 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I swapped out my 2:73 rear end for a 3:42. I am going about 10 under what the speedo reads at 70 mph. The gap grows w/speed. I would like to know what gear to use. By the way, the car (86 z28 IROC) seems to like the gears better.
Old May 7, 2009 | 06:21 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Changing tranny gear.. Which one?
T-5 or 700R4?
JamesC
Old May 7, 2009 | 06:37 PM
James.. It's a 700
Old May 7, 2009 | 10:47 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
i did that same swap. I have a 15 drive (gray) and 40 (black) driven. That seems to be right but i just put the 40 in today because the 41 (yellow) tooth gear read 3 mph low.
Old May 8, 2009 | 07:37 PM
was the right gear a black gear with 40 teeth? is this the only gear to replace?
Old May 8, 2009 | 09:08 PM
Car: 86 Z28
I'm pretty sure that the black gear is the correct gear, but i haven't had a chance to check it with a gps yet. Also you would need a gray drive gear, and a new housing for the driven gear(different housing for 39 up gear)
Chevy3shitty
Sep 1, 2015 09:22 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
