Some info on the dredded B/W 9 bolt.......
Old Jul 25, 2001 | 11:45 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Well i just did my swap from a 89 2.77, to a 87 3.27. As i took the 3.27 apart i learned alot. Here are some of the numbers i found. the axles are 28 spline.It is has full length 1 5/16 inch shaft to where the splines enter the posi where it tapers to 1 1/8 inch. The 10 bolt , (which i had one next to it) has 1 1/8 inch shaft tapered to 1 1/16 in the posi. HMMMMMMMM. No C-Clips, tapered bearings, and a cone (rebuildable) posi, why would you not want to keep this rear. I agree 2.77 bite, but with good tires i could have been looking at 14.1 at 98.8 with that those gears. Now i have my $200.00 3.27 and i couldn't be happier. Well to each Their own. The Shaggy Iroc
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.4@ 98.8 MPH w/t-5, can't wait for to install my 3.27 B/W.
so much to do , so little money
Old Jul 26, 2001 | 01:42 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yep, I found the same things when I did my 91 10-bolt to 89 9-bolt swap. I hope you put the 89's brakes on the 87 rear end. Or did you put the 87's internals into the 89 rear end?
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jul 26, 2001 | 06:57 AM
ausrs's Avatar
well funny enough GM used the 9 bolt as the heavy duty option on 3rd gens ammazing thing is everyone wants to make their cars stronger BUT puts the ****ty 10 bolt in !!!! i dont understand
btw parts and stuff should be available real soon in usa lots of different ratios
Old Jul 26, 2001 | 09:13 AM
yep, i kept the brakes, 11.65" PBR. I just yanked the axles out and swapped backing plates. Then threw my calipers on. I did the whole swap in 5 hrs, but then i can pull the rear in 30 minutes. Wow, gotta say I am shooting for 13.99 at the next TNT, with my drag tires of course
'89 SHAGGY IROC
Old Jul 26, 2001 | 03:01 PM
sleeper's Avatar
While the B/W setup is stronger it is also much more expensive to fix and is very finicky.
I will gladly trade my B/W setup (3.27 with new calipers, cables, hoses, and rotors) to anyone with a posi drum setup.
Old Jul 26, 2001 | 07:45 PM
Kevin91Z's Avatar
Sleeper, I wish you lived closer because I have a 92 10-bolt 28-spline axle 3.23 drum brake rear end for sale.
Old Aug 2, 2001 | 02:38 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
<font face="Verdana, Arial" size="2">Originally posted by irocnroll89:
Well i just did my swap from a 89 2.77,....
</font>
Question for ya, my understanding is that the cone posi is NOT rebuildable, and that the whole carrier needs to be replaced as a unit.
Do you have access to parts for a rebuild? Please share.
Old Aug 2, 2001 | 03:08 PM
look in the archives, and/or tech. There is info on "how to shim the 9 bolt" in there. A guy from HUNTER MOTORPORTS up in canada did a instructional on it . If you can't find let me know, i have it printed , and can send a copy. THE SHAGGY IROC
'89 SHAGGY IROC
L98, W/C T5, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc. 14.4@ 98.8 MPH w/t-5, installed my 3.27 B/W, SHOOTING FOR 13.99, saturday.
[This message has been edited by irocnroll89 (edited August 02, 2001).]
Old Aug 2, 2001 | 09:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Thanks, I have that info, but you realize that's just doctoring it up and once the cone is gone, you'll need a new carrier?
You had my hopes up for a minute
Old Aug 3, 2001 | 06:07 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Well, you can shim the cone BUT if the cone s have eaten into the case - it's time for a whole new carrier.
GM isn't carrying carrier halves or cones anymore (if they ever did I dunno) - just the whole carrier. $1033 list. $619 on GM parts direct.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Aug 4, 2001 | 03:23 PM
c350b's Avatar
i have a 88 gta with the 9 bolt i am looking for a 3.70 or 3.73 r&p dose anyone know where i can find one or the other any info. would help very much because i have been looking for a lon time
Old Aug 4, 2001 | 08:16 PM
Saywhut's Avatar
Try this: http://www.drivetrainspecialists.com...=29&cat=GM+8.2
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
