Need TCC Lock up Switch for Dumbies
Old Apr 23, 2009 | 07:52 PM
OS3Fleming's Avatar
Car: 1984 Camaro Z28
Engine: 357 SBC
This is what I gathered thus far.
1. Purple (+) from brake switch to toggle switch
2. From Toggle to Harness
3. Ground from Trans Case to Pressure Switch pluged into the 4 gear port.
4. From pressure Switch to harness?
Please some one tell me this would work.
Old Apr 23, 2009 | 10:43 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
Re: Need TCC Lock up Switch for Dumbies
all I did was connect the f terminal from the aldl(tan/black) to one side of a toggle switch and the other to the a terminal on the aldl(black/white) or any ground. flip the switch on and the tc will lock up in any gear execpt 1st...works great
Old Apr 23, 2009 | 10:49 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
What is locking it up good for? Better gas mileage? What are the advantages and disadvantage?
Old Apr 23, 2009 | 11:21 PM
OS3Fleming's Avatar
Engine: 357 SBC
I currenlty get 16 -18 mpg, and I plan on driving from KS to VA so I would like not to burn up the trans.
I do not have the wire harness that came with the car. I do have a connector and the pressure switch for the four gear port. I just wanted to know if I could use the wire coming from the brake switch for an ignition source.
BRoss99
Aug 10, 2025 05:08 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
