rearend moves
Old Aug 5, 2001 | 05:06 PM
88greyiroc's Avatar
rearend moves
ok the other day i was leaving work and i was goin leftand the back end felt like i had a flat tire you know how the car wiggles around on a flat tire it felt like thatbut i got out and look and everything was fine both tires were great so could it be possible that my rear end is moving around that somethin could have came loose . and also if i go any fast that 80mph my car shakes really bad and i think that it could also be caused by that . anyone with any ideas reply please
Old Aug 5, 2001 | 05:59 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Take a look at your Panhard bar or Track Bar (depending on what you call it). This is what keeps the rearend centered. Don't overlook other rear suspension pieces though, including all the bushings and sway bar endlinks.
FREE CARFAX Record Check
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
