Squeeling rear wheel
Old Apr 27, 2009 | 02:55 PM
Kwijybow's Avatar
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
So I had a new diff put in the back of my car. The diff had entirely new brakes installed onto it, so I don't think its the brakes squeeking, but its been suggested that I may need new wheel bearings. The squeel only seems to be coming from the back right wheel and it squeels pretty much every time the car moves, braking or not. However, the squeel does seem to get louder when I hit the brakes, or when I make a hard, fast turn. What do you guys think?
Old Apr 27, 2009 | 02:58 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Squeeling rear wheel
Does your e-brake work okay? Have drums? Have you checked to see if maybe one of the e-brake cables might not be rubbing? Check the e-brake adjuster link / bolt. It might be rubbing on the drive shaft.
Old Apr 27, 2009 | 03:00 PM
Kwijybow's Avatar
Engine: Carb'd 305
The rear end I had installed upgraded me to disc brakes in the rear. The e-brake does work and the cable was replaced when I had the diff installed. I'm wondering if maybe the mechanic who did the swap did everything right...since I did get it done at Canadian Tire. :S
Old Apr 27, 2009 | 03:07 PM
Wadebryant's Avatar
Probably a disk rubbing and or they did not use anti-squeal when the pads were installed. That's my guess as I've done this mistake myself.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
