A Little problem with pulling the tranny - Please Help!
Old Aug 6, 2001 | 12:14 AM
maksik7's Avatar
Hey everybody,
I started pulling the 700R4 from my parts car today. I disconected all the lines, driveshaft, bell-housing bolts but the problem is I can't disconnect the Torque Converter bolts. The engine is siezed and to get all the converter bolts you have to able to turn the flywheel a full circle (and I can't do that). As far as I know the converter's attached to teh flywheel with 3 or 4 bolts, right?
Anyways how would you recommend gettting the converter off with a siezed engine. Is it possible?
My other option is to just take the tranny off and leave the converter in, but I am not looking forward to a tranny fluid bath plus the guy said the converter was a new aftermarket replacement...
Any help would be very appreciated,
-Max
86 Trans Am LB9/700R4
-Flowmaster 3inch exhaust, K&N, Ported Plenum, Redone Ignition system
Old Aug 6, 2001 | 12:26 AM
bhaas's Avatar
Put a couple of long bolts in the harmonic balancer and get a big pipe or bar and try to force it to turn or pull the motor/tranny and take the oil pan off then take off what rod caps you can get to and just keep trying to turn it. It can be a b*tch.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Old Aug 6, 2001 | 03:50 AM
transfixleo's Avatar
I don't know if there will be enough room but you may be able to pull the tranny away from the converter and leave it up there.
Old Aug 6, 2001 | 03:51 PM
FlaTToPP69's Avatar
try removing the spark plugs and see if the engine will rotate if not drop the oil pan and loosen the main or rod or both til the motor starts to turn no other way good luck better you than me
Old Aug 9, 2001 | 11:57 PM
Nordbert's Avatar
I clamp a pair of 10" Vise-Grips around the ring gear on the flexplate and push them
with my foot. Use real Vise-Grips ( I have
broken other brands) and wrap
some strong tape around the handles so you won't accidently release them while pushing
on them.
Old Aug 10, 2001 | 04:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I went through this situation... a friend had an '89 Camaro with a 2.8. It's oil pan cracked and he seized the engine. He bought a 2.8 for $100, so we did a 2.8-for-2.8 swap.
We unbolted the trans from the engine, and lifted the engine out. As the engine lifted, the convertor popped off the trans input shaft. The engine swung forward- but we were prepared, we removed the radiator.
Two out of three flexplate-to-convertor bolts were exposed. We couldn't get any wrench or socket or etc on the 3rd bolt, the block was in the way. To get the third, my friend used a sawzall to cut the flywheel enough to get a box wrench in there. We cut one long slit in the flywheel, then pried it back. Cutting through the ring gear took the longest.
If that didn't work, we were going to drop the pan and (hopefully) drop the crank down; assuming the crank wasn't melted to the block.
I know you don't want to pull the engine, though. Maybe if you get the trans out (by tilting the engine backward? Don't let it land on you when the convertor pops off the input shaft), you can work with a saw or cut-off-tool underneath the car.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Infested
May 22, 2018 11:56 PM
spaigo
Aug 21, 2015 07:46 PM
Zachattack0925
Aug 12, 2015 09:52 PM
hokis
Aug 9, 2015 03:57 PM
drathaar907
Aug 6, 2015 04:20 PM
