Normal Tranny shift points?
Old Apr 30, 2009 | 04:47 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
So my problem was that my tranny would shift into od at 39 mph. My buddy told me that the 700r4 should shift into od around 55-57. So I adjusted it to be just like that. Is it normal for my 88 camaro to shift into OD at 55-57? I think it may be 5 mph to high. Any ideas!!
Old Apr 30, 2009 | 06:08 PM
AKATDOG's Avatar
Car: 84 Z28
Re: Normal Tranny shift points?
mine stock shifted at 80 kmh
Old May 1, 2009 | 03:56 AM
Pro Built Automatics's Avatar
39 is about right, as long as the other shifts are at the right speed. 37-47 mph is what I have seen over the years, and this is normal for 3.23 - 3.73's. Thare always exceptions.
Old May 2, 2009 | 11:24 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
39 is way to early to be shifting into OD. When it does its so low in rpm the car shakes violently
Old May 2, 2009 | 04:19 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
check and see if the torque converter clutch is not locking up on you
Old May 2, 2009 | 04:51 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
its locking up. When I take my foot off the gas the rpm's go up around 100-150 rpm so I know its unlocking. i will figure this out someday
SlowAZ28
Sep 2, 2015 05:19 AM
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
gwade12
Aug 8, 2015 08:17 AM
