Removing 9bolt rotors.... What's the trick?
Old Aug 13, 2001 | 07:00 AM
Saywhut's Avatar
I can't seem to get 'em off, tho I've soaked them with Kroil, tapped, pried, beat with a soft faced hammer, looked for hidden bolts, done everything I know.
Looked for a puller, can't find one big enough.
I need to get 'em off so I can get the axles out, what am I missing?
Thanks!
Old Aug 13, 2001 | 08:07 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Same as any other stuck on rotor... not just limited to 9 bolts.
If somebody took a few seconds a long time ago and put some anti-sleaze compound on the hub then they wouldn't stick... however, most don't and there's rust that forms and you get what you got.
Mine were stuck on the chicken when I got it and it needed 1 rotor real bad anyway... by the time I got done with the sledgehammer it needed both.
I bought a rear brake drum puller and that didn't do squat.
Your other option is to heat up the rotor with a torch.
Good luck.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Aug 13, 2001 | 10:15 AM
Saywhut's Avatar
Thanks Brian, that's what I thought, Looks like I'll keep soaking them, as the rear is not in the car, so time is not a factor.
Old Aug 13, 2001 | 11:44 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I still have an axle sitting on my shed with a rotor stuck on it. I went to 28 spline axles and never bothered trying to get the rotor off.
Old Aug 13, 2001 | 07:54 PM
TexasLT1's Avatar
Car: '92 RS
when I dismantled my 9 bolt, we got the cutting torch out, set it low, and heat the drum and axle continuously for almost 5 minutes and it still didnt want to come off. finally, we just beat the f*** out of it and slid id off little by little. I already needed the other rotor so why not go for 2?!
-'92 RS with self-installed '95 LT1
-Heddman Headers
-TPIS throttle body airfoil
-MSD 6-AL Ignition
Kills
-'97 Mustang Cobra
-'98 V6 Camaro
-'89 5.0 ****stang
-'97 Sebring
-'96 ****stang Cobra
Losses
-'99 Mustang GT
-'96 Mustang Cobra
-'95 Z28 (good race)
-'96(?) Turbo Eclipse (d*mn good race, heavily modified)
Old Aug 13, 2001 | 08:55 PM
Saywhut's Avatar
Thanks guys, I got them off, I got a peice of pipe between the rotor & axle, pried it& hit the rotor, rotated the axle 90 deg., did it again, and repeated till it came off.
No busted rotors or anything.
I had tried this method at first, but today it worked, maybe it was the 2 cans of penetrating oil I've sprayed on it in the last week?
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
87hellbird
Sep 14, 2015 05:08 PM
buckshot63
Sep 10, 2015 09:15 AM
hdis2002
Sep 8, 2015 02:52 PM
