will a v-6 tranny and bellhousing work behind a v-8?
Old Aug 14, 2001 | 01:45 AM
83CrossfireBomb's Avatar
i have access to a free bellhousing, pedals, and other stuff from a v-6 car. dont get the tranny though. i was wondering if a f-body v-6 bellhousing will work behind a v-8, its said to be from a 2,8 v-6 also.
if it will work, can i bolt any tranny to the bellhousing or do i need an f-body tranny?
also, i have a 700R4 in my 83 crossfire car now. i just put in a carb'ed 350 and i dont have the TV cable hooked up because i need to find the right bracket. ive been told i have to replace the TV cable because the crossfire ones wont work with a carb. i have driven the car and it doesnt shift hard anymore. i know there was somekind of shiftkit put in the car by the previous owner and it would chirp the tires hittin 2nd everytime with my tired 305, now it shifts like grannys buick.
would that be because the TV cable isnt hooked up?
any info apprietiated
former 305 crossfire fuel injection
350 cubes
hooker headers
750 vac secondary
700r4 with shift kit
Old Aug 14, 2001 | 01:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Definately; the 700r4 lives off that TV cable. Run without it, and you can burn the trans up due to insufficient line pressure.
-Tom P (Hot rodded 1986 Firebird 2.8l)
Old Aug 14, 2001 | 04:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
And no, the V6 bellhousing won't fit on a V8
Old Aug 14, 2001 | 09:49 PM
berts's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
And no, the V6 bellhousing won't fit on a V8</font>
Only a tranny for a chevy 4.3 v-6 bellhousing would work to a chevy v-8 small block, but keep in mind you also need the right flex plate or fly wheel for a good counter balance. this is including cable and top load shift 4-6 speed trans. the only other bad part is the tail bracket mounts on the tranny from the rear axel to trans strut. that means "the short tail tranny"
gta90
Sep 15, 2015 04:00 PM
383backinblack
Aug 15, 2015 06:36 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
drathaar907
Aug 6, 2015 04:20 PM
