questions about 700r4 hookup in a 1982 t/a swap
Old Aug 13, 2001 | 11:22 PM
mark406's Avatar
im going from a 4spd stick to a 700r4,my question is after the tranny is in and stuff wut all do i have to set an adjust? i need to get a tv?cable.an anyone help me on this i have the tranny in now and need to figure out how to hook the **** up lol..wut about tq conv lockup? my car is carbed with no computer.82 transam 400sbc tranny is from a 88 gta 350. any and all help is apreciated!
Old Aug 14, 2001 | 07:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You need a TV cable appropriate for the induction you have (as well as appropriate bracket). Adjusting this cable is the only "adjustment" needed, check archives for details or go by the book.
The lockup can be accomplished either with a manual switch you flip while driving, or with a kit from Summit/Jegs etc.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, ZZ3 intake, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam, ported World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Aug 14, 2001 | 08:05 PM
mark406's Avatar
how do you wire this switch up?
Old Aug 14, 2001 | 09:42 PM
82camaro's Avatar
Car: 82 camaro SC
I don't have the diagram in front of me, but one of the wires that goes into the tranny needs 12V whenever the key is turned on. Another wire needs to be grounded. Using a switch ground that wire when you want the torque converter to lock.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 15, 2001 | 01:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Here's one way of wiring the TCC lockup: http://www.thegrid.net/thedrivetrainpage/700inst.htm
-Tom P (Hot rodded 1986 Firebird 2.8l)
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
