What year is my T-5?
Old Aug 16, 2001 | 10:51 AM
fst5spd350's Avatar
Is there anything I can decode or a number or year on the casted on the tranny? Also, how can I tell if it's a world class tranny or not? First post for me YEAH!!
Old Aug 16, 2001 | 12:00 PM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Go to http://www.5speeds.com/ , then click on the T5 5speeds on the left side...
then read.
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Old Aug 16, 2001 | 12:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is a tag they stick on, it's white with green printing. You can decode the numbers and tell about the year, but I have no idea how, nor do I see any value in doing that since there are no year-to-year changes, so I have never bothered to find out how...
The 1st design T-5 has straight roller bearings on the countergear, and all brass synchro blocking rings. The 2nd design "World Class" has tapered rollers on the countergear, composition blocking rings on 2nd and 1st (why?!?!?) gears, and needle rollers between the intermediate gears and the mainshaft for reduced friction. Externally they are identical in size and bolt locations and all that, so they are totally interchangeable without any other changes being required.
You can tell them apart easily from outside the case, even while they are installed in the car. Look at the front countergear bearing, which is in the front surface of the case where it sits against the bell housing; the bearing is to the pass side of center near the bottom, about 1/3 of it is exposed below the BH. The 1st design bearing is flat and very shiny, with its edge rolled over, such that it looks like an upside-down freeze plug. The 2nd design bearing has a dull finish, and has its center depressed; it looks almost like it has a ridge about 3/16" wide all the way around it. It has sharp edges that don't look rolled over at all.
ICON Motorsports
Cornholio7979
Sep 20, 2018 02:31 AM
92GTA
Apr 9, 2016 07:39 AM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
