What speedo combo is green/driven, blue/drive on a 84 T5?
Old Aug 13, 2001 | 07:07 PM
86IROC305's Avatar
The car I pulled the tranny from (84 HO Z28) "should" have had 3.73's from the RPO's, but it had a 87 3.45 9bolt. I need to know if there is such a thing as a blue drive gear(T5) or is it really purple and the color has changed(?)
I don't know how many teeth it has (tranny's at the shop), and I need the white/purple combo for my setup(3.45's). So it would save me about $20 if I only had to replace one gear..... Thanks
86 TPI 305 Iroc-Z
700R4 (rebuilt)
9 Bolt Rear Disc Swap
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
212/212 444/444 @112lsa
Old Aug 14, 2001 | 12:21 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There is a blue drive gear. It comes with 7 teeth. You can use purple or white driven gears with it. IIRC for 3.42s you want 7 and 20 or 21 depending on tire size. Right now I have 7 blue and 19 purple in my T-5 with 3.73s.
ICON Motorsports
Old Aug 15, 2001 | 12:27 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Stock for 3.42/3.45 is 7 tooth purple(blue) and 19 tooth white. The 20 or 21 is for 3.70/3.73. But it depends on your tire size too.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Aug 15, 2001 | 06:10 PM
86IROC305's Avatar
I went to the shop to take a look at the gears and it allready had 7/19 combo. The white is a little off color and looked like a light green, so I guess I lucked out and didn't need to change gears..... Thanks for all the help though.
86 TPI 305 Iroc-Z
700R4 (rebuilt)
Accel HEI SuperCoil
Flowmaster
K&N Filters
Comp Cams 260H-12
[This message has been edited by 86IROC305 (edited August 15, 2001).]
Old Aug 16, 2001 | 12:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Oops I got it backwards... Kevin is right... I took the 19 purple out and put the 21 purple in, not the other way around.
ICON Motorsports
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
