4L80E ??
Old Aug 16, 2001 | 02:50 PM
jeepman's Avatar
4L80E ??
Newbie here, with a question about the 4L80E. Will it work OK behind the 305 TPI computer from an early 90's camaro or firebird? I'm wanting to install this combination in a 84 cj-8 jeep
Old Aug 16, 2001 | 03:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You'll need an aftermarket computer to control the shifting.
Old Aug 16, 2001 | 04:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Plus you need to do some sheetmetal work. It's bigger than a TH400 and very heavy. Since it's a completely electronic tranny you need a computer just to operate the tranny.
It's overkill for a 305. My truck has one in it from the factory and with the big block in front of it, the truck is the lighest vehicle they put this tranny into.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Aug 16, 2001 | 10:02 PM
Crosley4's Avatar
I will point out that if you plan on bolting up a transfer case to the 4L80E the back of the transmission case on the 4L80E is different from a T400 trans.
Old Aug 17, 2001 | 03:45 AM
transfixleo's Avatar
The 4L80E is overkill. It is VERY heavy and not as reliable as people seam to think it is. They love to break all kinds of parts and require a computer to operate it.
Old Aug 17, 2001 | 08:13 AM
jeepman's Avatar
Thanks for the info. You talked me out of making a mistake.
oldred95
Mar 19, 2020 03:03 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
zride91
Aug 22, 2008 10:53 PM
Vortex91
Jul 19, 2007 08:28 PM
Hoss50
May 30, 2004 12:08 AM
