Bent Axle
Old Aug 17, 2001 | 09:09 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
Bent Axle
Well I Have A Bent Axle On My 88' 9 Bolt BW Rear End. Well What Would You Guys Recommend. Replacing The Axle Shaft? Is It Too Much Work Or Even Worth It? Take In To Account That I Have No Experince With Rear Ends. Or Pull A Newer Rear End? If So What Year and Type. 10 bolt? Thanks In Advance. All Suggestions Are Welcome
88' IROC-Z, 350 TPI, 700-R4
Old Aug 17, 2001 | 09:47 PM
Car: 1988 IROC-Z
Oh yeah the rear brakes don't work on the current rear either.
Old Aug 17, 2001 | 11:11 PM
Project86Iroc's Avatar
Well, first and foremost, find out WHY the brakes dont work. Is fluid getting back there properly? are the calipers just not engaging? If the problem is in the axle side, not master or prop valve, I would recommend you go for a newer SS rearend. the ss comes with either 3.42 or 3.73 posi, Disc rear, will drop right in(I think the axle tubes are about 1/2" longer on each side, so your rims will stick out a LITTLE more. but for what youll pay to put an axle in your rear, why fix something with high mileage, thats hard to get parts for, and most parts are faulty anyway? a good 4th gen rear can usually be had for 350 or less at a junkyard if you let them keep the ABS junk(which is useless to you anyway)
"Experience life, Don't use it" Julie (petrick) Fink
[This message has been edited by Project86Iroc (edited August 17, 2001).]
Old Aug 18, 2001 | 12:06 AM
Car: 1988 IROC-Z
Well the brakes do not work. They are getting
plenty of fluid back there. Master cylinder is ok and prop valve checked out. The calipers do not apply enough pressure to stop the rear wheels from spinning while car is on stands in drive. I have heard many complaints about the J65 rear braking system on these cars. Since i have a bent axle and inoperative rear brake system it seems like a good enough excuse to get another rear end. I'll good ahead and begin looking for a new rear end and see if i can get a good deal on one.
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Zell1luk
Sep 29, 2015 10:36 AM
dbrochard
Sep 7, 2015 09:41 AM
