Just changing gears, not carrier, whats involved?
Old Aug 20, 2001 | 12:52 AM
Project86Iroc's Avatar
Im picking up a set of richmond 3.42s for my IROC. theyre setup for the 2 series carrier, which is what im running. What is required to change this out. I know everyone says take it to a shop, but if I can avoid that Id love to. Btw, the car is an 86 2 3/4 Posi
"Experience life, Don't use it" Julie (petrick) Fink
Old Aug 20, 2001 | 01:31 AM
MouseCamaro305's Avatar
you can do it, you need a lift, or youre going to have massive headaches, but you can do it. youll need a micrometer, which is what you have to measure pinion depth with, youll need youre usual hand tools, a torque wrench, an installation kit, which includes shims, seals, races, and bearings, and marking compound. youll also need gear lube, and you could probably use some bearing grease also. youll need lots of patience, and a little more time. you need a dial indicator to measure backlash, it's kind of a chore, but its worth it. l had a real bad experience with installing my gears but l was patient enough to get it right, the 4th time. my advice to you is to do everything to a T. DO NOT RUSH, youll have major headaches if you don't take your time. it might take you a week to do it exactly right, but thats a lot better then throwing away a $200 set of gears. I was lucky enough to not have to buy another set of gears, but it took some time to get it right. now l could do it with my eyes closed.
eightsixseven
Dec 16, 2024 01:50 PM
hectre13
Dec 11, 2023 08:14 AM
jklein337
Sep 19, 2018 06:23 PM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
