Can ANYONE here tell me what years this tranny will work in?
Old Aug 14, 2001 | 05:12 PM
JeffP's Avatar
I've been trying to figure out for months now, with no luck.
Can anyone tell me what years an 89 700R4 will work in? I thought 90-92 had an electronically driven speedometer, so it won't work, right? Or will it? Will it work down to 87?
Here is the original thread. Any input on it as well?
https://www.thirdgen.org/messgboard/...ML/003196.html
TIA!!!!!!
Old Aug 14, 2001 | 05:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It'll work in any year, you'll just have to change the speedometer gears and housing.
Old Aug 15, 2001 | 04:16 AM
transfixleo's Avatar
So that is what you wanted to know. Why didn't you say that?
Old Aug 20, 2001 | 11:09 AM
JeffP's Avatar
Ok, well what about the connector with the different number of prongs? I know this tranny wouldn't work in a 93 Z28. And yes, all 93s are non-electronic...
You said this trans will work in all years...Does that mean all years except 93? I know for a fact it will not work in 93 F-Bodies.
Old Aug 20, 2001 | 11:22 AM
JeffP's Avatar
I'm just trying to get this figured out, sorry if I am coming across as impatient...
There is just a lot of conflicting information on the boards.
First, someone told me that an 89 transmission will not work in my 93 Z28 because the 4/5 prong connector issue. This was by someone who actually encountered this problem.
Then, someone tells me it will work in all years. BUT, then what about the 4/5 prong connection issue? It would be alot simpler if 4L60Es had the 5 prong, and 4L60/700R4s had the 4 prong. But with my 93 Z28, the 4L60/700R4 appears to have the 5 prong connector.
And this tranny will work in a later model F-Body that has an electronically driven speedo? I just need to change the speedo gear housing?
As always, Thanks a ton!!!
Reddeath210
Oct 6, 2015 08:20 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
