Question for TH350 cable
Old Aug 21, 2001 | 04:33 PM
88CRUZIN's Avatar
ok i was wondering about the harm that could happen if i run the car without the cable. the thing is that the cable doesnt reach the Holley double pumper i put on. i bought a mr gasket universal throttle bracket but it still doesnt reach. just in case how much would a new cable run me?
thanks for any info
88Cruzin
Old Aug 21, 2001 | 06:27 PM
Cosmik Debris's Avatar
I don't think with a 350 it will do any harm but you will have to downshift it manually.
Old Aug 21, 2001 | 07:08 PM
82camaro's Avatar
Car: 82 camaro SC
With the th350, all it does is downshift. So, you won't have a throttle activated downshift. The only harm could be from the added heat the converter will produce if you don't downshift correct forcing the converter to slip alot.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Aug 21, 2001 | 10:40 PM
88CRUZIN's Avatar
thanks guys, but one question is how do i downshift manually? its an automatic tranny. ???
88CRUZIN
Old Aug 21, 2001 | 11:53 PM
bhaas's Avatar
Just pull the shifter down to second gear. That's downshifting. That's what that cable does when it's hooked up. I don't have mine hooked up cause I was too lazy too. I just downshift it myself. Get a B&M Megashifter for it. You'll be glad you did.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Soon to be T5 YES!!!
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
