what the *^$* is wrong with my tranny? please help.
Old Aug 21, 2001 | 10:58 PM
kernel's Avatar
okay here is the deal.it takes off fine and shifts from first to second great but it never shifts to third gear.it stays in 2nd.and if i let of the gas and then put back on the gas it will just rev to like 2,200 rpms before it will accelerate. what could be wrong? tv cable? low on tranny fluid? bands,govener, valves? should i pour in some tranny cleaner fluid? please help.
1986 WS6 pontiac trans am
5.0 305 TPI V8
700R4 tranny w/transgo shift kit. borg warner wires,accel cap and rotr,delco plugs, K&N
KYB shocks,dynomax high flow cat,3"intermediate pipe,40 series flowmaster
w/2 3" tailpipes.
"ponys can run but birds can fly"
www.community.webshots.com/user/kernel20
Old Aug 22, 2001 | 12:05 AM
maksik7's Avatar
The reason it won't go into 3rd is the tranny needs a rebuild. I am guessing the clutch pack is fried. The reason is revs before going is possibly becasue the Torque converter is gone? Somebody correct me if I'm wrong.
Old Aug 22, 2001 | 04:48 AM
transfixleo's Avatar
Skip the cleaner in a can stuff. Does the 1-2 shift get later with throttle? If not then there is a throttle valve problem, which with the TransGo kit would probably mean that something is seriously coming apart to stick that new valve. Try having someone put it in Reverse while you pull the TV cable and release it a few times.
If it does get later with throttle but it neutrals when it should go to 3rd, the 3-4's are gone. If it just stays in 2nd then the 2-3 shift valve is stuck.
Dyno Don
Jan 24, 2016 08:24 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
