Can a T56 bolt to a 72 block?
I have a chance to get a built 350 for a good price but the block is a 72. Will there be any problems bolting a T56 to this? Are the bolt patterns the same for all year? I need to know if this engine is a good buy.
Adam
Adam
well i know that you will need the flywheel that is made for the 2 peice rear main seal. contact centerforce.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Brandon
The bolt patterns from the tranny to the block are the same. The only problem you'll run into is the 72' block uses a 2-piece rear main seal, and the T56 flywheel will not bolt up b/c the pattern is totally different. Centerforce makes a custom flywheel for this. I can't remember the part number, but it's listed on www.centerforce.com
It's about $270 IIRC.
Good luck, and HTH!
89' pearl blue Camaro Iroc-Z
355/6-spd
Not stock...
97' black Pontiac Trans Am
LT1, A4, free mods, CAI,
HPP3+, Flowmaster catback, 3.42's.
100hp Nitrous.
Good luck, and HTH!
355/6-spd
Not stock...
100hp Nitrous.
Yeah, you'll be ok. Just make sure your T56 is not a 98+ or you are in trouble, and need an LS1 to bolt it to. McLeod also makes that flywheel, and they have a better LT1 style pull off clutch, IMO.
Tyler
<A HREF="http://www.pro-touring.com/featured_cars/camaro/Tyler_Beauregard/tyler_beauregard.htm" TARGET=_blank>
68-LT1-T56
</A>
<A HREF="http://www.pro-touring.com/featured_cars/camaro/Tyler_Beauregard/tyler_beauregards_project_5050.htm" TARGET=_blank>
50-50
</A>
Tyler
68-LT1-T56
</A>
50-50
</A>
evilstuie
Jan 9, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
